I have the following setup in tests before installing it on a sailboat with some more Victron equipment:
- Cerbo GX
- Lynx Shunt VE.Can
- Lynx Distributor
- BlueSolar MPPT 150/60-Tr
- MultiPlus-II 12/3000/120-32 230V
- Battery Pack LiFePo4 12V 230Ah, with BMS 150A max. discharge, 75A max. charge
We have the system working but with some important configurations to be done and for which I would like your help:
- Is it possible to change the BlueSolar MPPT settings, namely absorption and float voltage? If it would be needed an extra cable I can buy it. I ask this because in the case of the MultiPlus-II I was able to change the “Charge” settings.
- Is it important, or does it make sense at least, that the charging settings should be exactly the same on the BlueSolar MPPT and the MultiPlus-II?
- Since my BMS limits 75A of maximum charging current, the MultiPlus-II can never run at its maximum current (120A). The BMS just cuts the load, it doesn't "limit" to 75A. How can I limit this current on Victron side, optimizing the system so that the BlueSolar MPPT and MultiPlus-II cannot exceed 75A charging? My doubt is the following: I have times when the BlueSolar MPPT is charging at 10A, others at 20A, others at zero. Do I have to limit the MultiPlus-II to a fixed current or can this be dynamic as there is communication between all modules via a GX device?
- In the Remote Consule of Cerbo GX, the AC-Out L2 does not appear. Is it possible to activate it to show somewhere?
- When observing the AC-Out L1 (current and power), I noticed that when I don't have AC-In L1 input, my load is consuming 100W (coherent with the equipment it has). When I turn on the AC-In L1, the inverter also starts charging the batteries and the AC-Out L1 monitor starts to display approximately 200W, without the load varying. It should keep the 100W. Do I have a malfunction in the MultiPlus-II?
