Hannes Swart avatar image
Hannes Swart asked
Temperature sensor error
I keep getting a Temperature sense error alarm, can I just disconnect it from my quattro?
Temperature Sensor
Alexandra avatar image
Alexandra answered ·
@Hannes Swart
Yes as long as you do not need temperature compensated charging, for instance if you have lead acid batteries.
But if it is a problem then disconnect anyway as if it is not working then there is no point to having it there.
Victron temperature sensor disambiguation table - which product supports which sensor
