I would like the configuration to be different since the red led is annoying since the low voltage alarm is together with the inverter restart .
I have programmed that the inverter restarts at 12.30v, but it is annoying that the red led lights up because 12.30v also indicates that the battery has low voltage
In the múltiplus the reset and low voltage alarm options are different.
Phoenix Setup Menu
Múltiplus settings menu
