If there is a Smart BMS 12-200 installed, what is the best way to connect the alternator when there is no start battery. The house bank is charged by a dedicated standalone alternator. This is on a 40 Ft motorboat.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
As its bad to connect a alternator to a open circuit situation thus turning its main outputs connection to a battery OFF - I would sugest that you used WS500 regulator as these have a remote shutoff and lots of other options (not sold by victron) or have the alternator modified so that the field power can be turn off and on by a relay - then you could connect the alternator direct to the battery and if charging needs to stop then use the charge relay output connection on the BMS to turn charging off /on via the new installed field relay
27 People are following this question.
