I have two SOK 12 volt 100 Ah batteries wired in Series for 24 volts. My Connect App shows "Starter Battery" under Input: 26 to 27 volts depending on load, charge... this is a correct display. The Output section on my Connect App under "Voltage" shows 13.03 volts at the moment. I am completely confused as to what is causing the approx 12 volt voltage display since my system is a 24 volt system. Can you advise what might be causing this?
Also, I will admit that the term "Starter Battery" means little to me, this is an off grid system that I have designed and installed to run a home freezer and a few small items like lights. Do you know of any resource that actually explains why my battery bank is displayed as a Starter Battery? (Did I purchase the wrong battery monitor for what I am using it for?)
