wyliewml8 avatar image
wyliewml8 asked
monitor two 12v batteries in series
I have two LiFePO4, 12v, 60ah each, connected in series. Running a 24v, 70lb trolling motor. I have a BMV-702. I'm at a loss of where to connect the BMV positive cable(s), the load end of the BMV shunt, the battery end of the BMV shunt, and anything else I need to know. Assume I'm ignorant about wiring and then it is more likely I can understand the answer! Thank you, in advance, for your help!
battery
klim8skeptic avatar image
klim8skeptic answered ·
BMV quick install guide.
Have a look at #12.
wyliewml8 avatar image wyliewml8 commented ·
Thank you!
