My current gel batteries (12v) are all run individually to a common post vs a normal parallel daisy chain. I am switching to two 330ah Victron lithium batteries connected to a Lynx Smart BMS. I have seen this done with a Lynx distributor with each batter individually fused. This uses a mega fuse and I thought a Class T fuse was necessary to provide adequate AIC protection(2.0,000 amps)
in this case the BTV cables are daisy chained into the BMS.
can anyone comment on the pros and cons of mega fuse in the Lynx Distributor vs a Class T fuse?
