Hi everyone, I'm trying to use two different MPPT's for my solar panel set up. My panels are 6A and 150V total. I'm planning on having two different arrays of roughly 6A each of 100V and 50V connected to two different MPPTs. I was just wondering if putting the two MPPTs in series with each other would be an okay idea and what if anything I would need to do to do this?
The reason why I have to use two is that the MPPTs have a much lower wattage rating than the array of 600W and 400W each. I understand that having them be in parallel is a much more optimal solution but I can't do that since I'm using two different MPPTs with different voltage outputs.
The two MPPTs I'm using are https://www.victronenergy.com/solar-charge-controllers/smartsolar-mppt-75-10-75-15-100-15-100-20#victronconnect-downloads and https://www.emarineinc.com/AERL-RACEMAX-MAXIMIZER-MPPT-Solar-Car-Controller-600B. Any help would be greatly appreciated.
