We have a two Cerbo GX modules where both modules fail to start.
we have checked all connections and they are correct tried using the units with no connections other than the power and are having no luck with the modules starting up. The wifi and bluetooth LEDs flash briefly but can't be cycled through using the reset button to enable/disable.
Concerningly the modules make quite a sparking sound when the power connector is plugged in (can be observed in the attached video)
it seemed as though the first module was a faulty unit however it seems very unlikey that we would have two faulty modules in a row.
does anyone have any advice on what might be happening here? is the sparking noise normal when connecting the module (inrush)?
Thanks,
