Victron 12/1600/70. I have installed a Victron inverter charger on a boat. Shore power is connected to the inverter which is then distributed to the sockets on the boat. Question is: if I leave a heater or a dehumidifier running and for some reason I lose shore power. Will the inverter run the appliances till the batteries are flat. Thank you
