I have a Multiplus II, Cerbo GX, Victron MPPT and a Fronius inverter. The fronius is on AC IN. The system works fine. When there is sun MPPT charges the battery together with the Multiplus II from the energy produced by Fornius as long as the house load is covered first.
My electricity price is variable and changes every hour, i have made some automation in Nodered to start charging EV when the electricity is at it's lowest BUT i don't want to use the battery for charging the EV since i want to buy from the grid. I want to keep the battery when the energy is expensive.
I have access to Modbus and MQTT so i am looking for suggestion what i should do in case i don't want to discharge from battery. I tried the Switch mode from Modbus 33 to set to Charger only and that works since the MPPT can continue to charge battery while i buy from grid but the question is, is that the correct way to do it ? There are also Hub4/DisableFeedIn but the name doesn't sound correct because i want DisableDischarge. Maybe setting the gridpoint could do this ?
/peter
