Please assist with cable size required for 2x 100ah lithium batteries connected in parallel? Distance between the batteries is approximately 2meters.
The max draw in the system is a 2000w inverter that peaks at max 196amps. I’ve had a few conflicting answers.
Just need to know the size of the cable that will connect the two batteries in parallel. Also will it be advised to have a fuse between the positive terminals as well? And will it be rated at max amps drawn from the system, ie 200a, or max from one battery which is 100a?
