@Victron
There's a slight bug in the flow upon working without a smartmeter (all loads behind inverter)
Please have a look @ section Multiplus -> AC-Lasten
The direction is wrong, Fronius inverter should deliver via Multiplus to Battery
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
@Victron
Hi @N-DEE,
I have seen similar things myself on occasion. Sometimes refreshing the window will correct it.
Or is it consistently wrong and a reproducible situation for you? If so, what is the system name to help an engineer have a closer look.
Also, out of interest did you see if it was correct on the GX device display at the same time?
ID 58337
It is reproducible (never was correct). Reload doesn't help here.
Chart in GX wasn't adjusted at the time it was adjusted in VRM (flow goes from Fronius into Mutliplus which is not right) - so I'm not able to answer the question at all.
35 People are following this question.
