Hi All,
have a small setup in the caravan and would love to have more than 2 relay outputs controlled from the Cerbo GX. What is the most self-contained way I can do this?
On my system at home, Node Red running on the Venus GX can control my zigbee relays over MQTT, but this setup requires I have a network router and zigbee bridge running all the time. At home, this is not a problem because they are in constant use by the smart home devices anyway, but in the caravan, I'm trying to minimize how much stuff needs to be left on.
Your input is much appreciated.
Many thanks
