crispin avatar image
crispin asked
New install - Easy Solar -Unit located around 130m from mains feed
Hi folks,
First time poster and user of Victron equipment - long time user of PV in larger DIY systems.
It's been recommended that I use an Easy Solar 5000 along with 11KW/h batteries. This will be used to "augment" my mains supply. I seldom go over 3KW in usage so all good.
My confusion though is the installer is suggesting I need a sensor on the incoming so the unit knows how much to generate. Makes sense I guess. Where I will have my inverter will be around 130m cable run.
two questions:
  1. Do I need the sensor or will the unit work it out itself? (I've seen a few confusing posts in this community)
  2. If I do need it, how will I run a CT sensors 130m? Is there a "digital" or wireless option?
Thanks
C
EasySolar All-in-One
kevgermany avatar image
kevgermany answered ·
In normal operation, easysolar passes the grid to the AC loads. If grid inadequate, it will supplement the grid. Automatically.
What is the sensor supposed to do?
