arghhh40k avatar image
arghhh40k asked
Issue with Venus Docker Unraid with existing Influx Grafana
Have the Venus server and UPNP dockers installed with a existing Influx 1.8 and grafana installation. The server can find my Cerbo via local discovery but I get a error in the log after a minute or so.
FetchError: request to http://169.254.10.138:34297/com.victronenergy.ccgx.D4:12:43:0B:57:40.xml failed, reason: connect ETIMEDOUT 169.254.10.138:34297
The address if the Cerbo is 192.168.1.114.
No data is ever logged. I had the same Cerbo set up with a Pi and had it working well. MQTT plaintext is on.
I am also getting constant grafana connection issues. The server successfully created the influx DB.
2022-03-06T17:42:37.296Z
info
influxdb Attempting connection to 192.168.1.253:8086/ess
2022-03-06T17:42:37.298Z
info
influxdb Connected
grafana
arghhh40k avatar image arghhh40k commented ·
Ok the issue I was having is a wrong retention setting, I forgot the units. I wanted more than 30d so set it for 0 and forgot the d after it.
I am still getting
FetchError: request to http://169.254.5.45:34087/com.victronenergy.ccgx.D4:12:43:0B:57:40.xml failed, reason: connect ETIMEDOUT 169.254.5.45:34087
but everything seems to work ok.
n-dee avatar image
n-dee answered ·
Hi!
I'm trying to setup a grafana dashboard in Unraid and don't know how to move on with the yaml file.
Any help appreciated!
Thanks,
Andy
sim-1 avatar image sim-1 commented ·
I just made a guide:
https://community.victronenergy.com/articles/248383/guide-installing-victron-grafana-dockers-on-unraid.html
