Hello Victron Entusiasts,
I run a victron Quattro 24/5000 system with OPZS Batterys succesfull since about 9 Years. Now the
OPZS Batterys are on the end of the Lifetime and i switched now to the following System.
4*MPPT 150, 2*MPPT250, Quattro 48/10000 , Venus GX, 5-14 Pylontec Batterys US 3000C.
All is running well.... The Quattro is programmed to 8000 W, if i exceed this power, the quattro switches back to the Grid.
In this new configuration this is a Problem, because the main fuse goes of over 5500 Watt's.
Now my Question
Is there any way that, if i consume 10 000 Watt's the quattro delivers 8000 Watts, and than the Quattro adds the lacking 2000 Watts from the Grid ?
Thanks for your help
Uli U. aus Ss
