I am looking at installing an IP22 24V/8A charger within a system. The power cable reel I am using is rated to 8A wound with a 5 metre cable length. Power supply is 240V/13A, I need to know the PEAK in rush current on the AC side for this particular charger as it is not listed on the spec sheet,
