See below graphs,
Battery Temparture is not changing
No added 24V usersQuattro is on charge only
What can cause these spikes?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
See below graphs,
Maybe the scaling on the graph is making it look awful. There is too much data in a small space. and not enough resolution for anything there.
If you zoom in over the peak sections what does it look like?
from what is looks like at a general glance you are floating around 27 ish volts.
Maybe the spikes are a fluctuation caused by bms misbehaving assuming you have lithium? Or fans in the multi switching on? Then it looks like a small charge going back in. The system would still be using a bit of power even in standby. Do you have a repeat absorption cycle on the battery bank? Is is matching the timing of the spikes?
The amp draw multiplied by volts would indicate about 25 to 40w of power. Again not enough resolution in the image to really tell, or state for sure.
It would be helpful to see the VE Bus chart for this period, the one that shows float/absorption etc. You say no added users. Does this mean none at all, or just that there are existing users, but no extras. If existing, what are they? I see something similar when my compressor fridge kicks in. And when the weather is cold, it doesn't turn itself on.
The resolution of the VRM / CCGX is now 1 minute.
I assume below behavior starts with a users at the 24V DC net.
But what user will cause such behavior and why does the system discharge shortly, can't the Quattro keep up the switching speed?
I know it's all small, but just curious.
54 People are following this question.
