I have a SmartSolar 100/30 connected up to a 200W Renogy Panel and a partially charged 200Ah Lithium battery. Using the Victron App the W, V and A of the PV and the battery fluctuate constantly (images for 5mins, but it did same for half hour).
I'm presuming that this is not the behaviour you'd expect to see on the app and it indicates some sort of wiring or connection issue in the system ?
Any hints on a diagnostic procedure and tools for the panel, cabling, connections etc would be appreciated.
NOTE: it was a typical Cloudy/Rainy day in the UK so not much power from the panel.
