I'm running a 100AH LiFePo4 Smart Battery in my RV using a BMS12/200 together with a MultiPlus 12/1200/50 (see attached Chart). Suddenly battery shows only 8V and System do not charge the battery. Normaly deepcharging should not not be possible due to BMS12/200 should stop discharching when Voltage goes below 11V.
I do not know what to do - is it possible to check separate cell Voltages? Btw. Bluetooth do not work anymore and I do not see Battery using Connect App.
I really would appreciate your help.
Thanks Sprollonis
