I want share node red ui via port forwarding function on my router, but he don't accept 192.168.0.xxx:1880/ui. He has a problem with /ui. is it possible define somehow without /ui or how you are doing it ?
Thanks
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Hi @Alda,
it should be enough if you only enter the ip address and the port. You can try that with your browser and 192.168.0.xxx:1880 - that's how it is working for me. Same for port forwarding in your router.
Hi @Stefanie
No, not working, it will open a editor.
It's very bad if isn't possible open dashboard Directly via VPN.
Maybe because your default user has admin rights. Take a look at this document: https://nodered.org/docs/user-guide/runtime/securing-node-red
I highly recommend to join the Node-RED forums. There are the real experts and very helpful people.
The recent update to the VRM app gives you a link to the Node-Red dashboard. No firewall port forwarding needed. Super easy!
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
39 People are following this question.
