I installed a Venus OS large on the Cerbo GX. All is working, but I want ask few questions :
1. From which where is better read data - as example batery data I can read from Battery but also from System
2. Is it possible make gauge two in one ? Like actual production and actual consumption in one gauge
3. Is it possible make a dynamic gauge min and max - means connect more inputs and somehow define what is used as minimum and what as maximum
Thank you.
