Hi all I have a Multiplus-II 48/5000/70-50, a big smartsolar charger and I have a Cerbo. ESS is configured for self consumption (Optimized mode).
The situation is that the building is on a phase that has two other buildings on it. But these other buildings don't have solar on them.
So what I want is maximize the input current, for dark periods that the buildings in total do not consume to much. But the grid feed-in can be set to a much higher limit.
For example I take a maximum of 1000W from the grid (and use batteries for but I can deliver 3000W to the grid.
All the solar is DC coupled, I don't have any AC coupled solar inverters.
In the configuration of the Multiplus there is only one AC current limit and it is applied for both ways.
(I know that any excess energy gets put into the battery, so it is not wasted. But it will be wasted when the battery is full)
Thanks in advance
