I found the manual page with "very" generic cerbo gx data consumption. Is there a way to find out what my current configuration is sending/receiving so it can be tuned to reliably work on a LTE-M connection? I have 3 Smartsolar controllers, BMV, SBS, 2 Temp Probes off the GX and a GPS antenna connected to the GX. Potentially a Multiplus compact in the future when my Magnum dies. As Victron makes an LTE-M device (currently with too few capabilities for me to use), I am pretty sure VRM will be able to deal with the very slow data uploads. I am not sure the lte-m connection will be fast enough for remote control but I will test that once I find a good router to use. I would probably disable firmware updates over that connection.
Sure would be cool if the VRM portal had a widget with that data information logged over time for us.
-Bill
