jj-o-jj avatar image
jj-o-jj asked
Temperature sensors multiplus ii +smart battery sensor
EASY Solar II GX, Smart Battery Sensor (Smart solar sees its temp readings), DVCC enabled, STS enabled, i DO NOT see SBS's temperature sensor in Remote Console>DVCC>available Temperature sensors. Why not?
remote console
jj-o-jj answered ·
8.4.3. Shared Temperature Sense (STS)
Select the temperature sensor to use; and the GX device will send the measured battery temperature to the Inverter/charger
system as well as all connected Solar Chargers.
Selectable sources for the battery temperature are:
• BMV-702 battery monitor
• BMV-712 battery monitor
• Lynx Shunt VE.Can battery monitors
• Temperature inputs on a Cerbo GX (and same for other GX devices that have a temperature input)
• Multi/Quattro inverter/charger
• Solar Chargers (if fitted with a temperature sensor)
