Hi, i have commissioned a system with 3 mppt solar controllers connected to a colur controller, the system also has a multi plus charger/ inverter And of course lv loads. I connected a lynx shunt batween the batteries and the load / solar and multi but inadvertantly connected the batteries on the riht hand side of the lynx shunt. There has been suggestions on forums that this will cause wrong SOC. Is that true?Also there have been suggestions that reversing the five wires in the lynx will correct the issue - is that correct?.Its a real big deal to pull out the lynx and recable as it is in a yacht and in a cramped position. There seems to be a number of contradictory posts in the forums. My supplier has been most unhelpfull.Can anyone ( Victron expertise) help. I need a simple solution. Tony
