Question: How do I access Node-RED in safe mode via VRM, and also access the Dashboard, via VRM Portal?
New user here. I have an R Pi 3B+ running v2.82 upgraded to Venus OS Large V2.82-large-30. I can access this installation via the VRM Portal. I have Node-RED set to "Enabled (safe mode)" and I can access Node-RED over LAN following the instructions in 7.1 at http://venus.local:1880 . All of that part is working fine.
However, I cannot access Node-RED in safe mode via VRM unless I set Node Red to "Enabled." Then the Venus OS Large menu item does appear as shown in the manual section 1.1. Selecting that, the Node-RED button appears--but not the button for Node-RED Dashboard. If I set Signal K to Enabled then the Signal K button also appears.
If I revert back to safe mode, the button no longer appears.
