olafd avatar image
olafd asked
Spikes in data collected from Ruuvitags
first, thanks to all for supporting Venus OS.
For the Ruuvitags I got often spikes in the collected data.
Solution:
To reduce the Bluetooth-Speed to 460800 - from 921600 via
/etc/udev/rules.d/machine.rules
- ACTION=="add",SUBSYSTEM=="tty",KERNEL=="ttyS0",RUN+="/usr/bin/hciattach -t 10 /dev/ttyS0 bcm43xx 921600 noflow -"
+ ACTION=="add",SUBSYSTEM=="tty",KERNEL=="ttyS0",RUN+="/usr/bin/hciattach -t 10 /dev/ttyS0 bcm43xx 460800 noflow -"
~# ps -l|grep hciattach
S     0   359     1  1892    84 0:0   16:26 00:00:00 /usr/bin/hciattach -t 10 /dev/ttyS0 bcm43xx 460800 noflow -
Could this file please be changed in VenusOS?
Sources:
https://f.ruuvi.com/t/spikes-in-data-collected-with-rpi3/3669 //#5 August 10, 2019
https://ruuvi.com/setting-up-raspberry-pi-as-a-ruuvi-gateway/
Hardware: Raspberry 3B+
Software: VenusOS-Large-25
Venus OSNode-RED
johnny-brusevold avatar image johnny-brusevold commented ·
@OlafD
Currently testing out ruuvi tags on pi4v1.4
Can not find anything on the net about reducing the speed for this.
ENV{BASE_COMPATIBLE}!="raspberrypi,4-model-b", GOTO="end-rpi4-model-b"
ACTION=="add",SUBSYSTEM=="tty",KERNEL=="ttyAMA0",RUN+="/usr/bin/hciattach /dev/ttyAMA0 bcm43xx 3000000 flow -"
LABEL="end-rpi4-model-b"
olafd avatar image olafd johnny-brusevold commented ·
Hi @johnny-brusevold
For the Ruuvitags I reduced the Bluetooth-Speed to 460800 for all Rasperries.
ACTION=="add",SUBSYSTEM=="tty",KERNEL=="ttyAMA0",RUN+="/usr/bin/hciattach /dev/ttyAMA0 bcm43xx 460800 flow -"
### ACTION=="add",SUBSYSTEM=="tty",KERNEL=="ttyAMA0",RUN+="/usr/bin/hciattach /dev/ttyAMA0 bcm43xx 3000000 flow -"
But haven't tested it with a Pi 4 - I have no.
Hope that helps.
johnny-brusevold avatar image johnny-brusevold olafd commented ·
Thanks for reply @OlafD
In my case none of this helped, but found the bug in the kernel bluteooth net driver, patched and tested that the errors are gone
