Also another client has a a question that I cannot answer with confidence.
Using a Victron 100/50 SmartSolar, if a LFP battery falls below the point that the BMS disconnects loads, can the 100/50 still get the battery to reconnect and accept a charge?
Is this dependant on the BMS/Battery or does that function work as stated in the Victron documents regardless of brand?
