Hello Victron Community,
I'm using the IP 22 Battery Charger (24/16/3) to load my two different battery banks. One Battery bank has two 12 Volt batteries in series with 150ah, the other battery bank has two 12v batteries in series with 220ah.
My question is as follows. I saw that the 150ah bank was fully charged and the other was only half full loaded. On both battery banks the tension was 28,8 volts. I would expect, that on the battery bank that is full the tension would be lower?!
Or is the tension still 28,8 even on the full bank but the current is 0 ampere?
On the app I only see the current value for all battery banks. For me it is interessting to know that i do not overload the battery with only 150ah.
Thanks for your help!
