silvanautic avatar image
silvanautic asked
Smart 12 200 Bms system positive
My I am currently stuck as I can not figure out which way is best for me to wire a multiplus to the bms.
A quick overview of the system I am installing;
12/200 Bms
Multiplus 12/1600/70
3x200ah lithium smart
2x mppt 100/30
Cerbo GX (with touch)
Smart shunt 500A
My question is regarding the system +. In the manual it appears that a multiplus can be connected to the system +. Therefore meaning both charge and load can be taken from this connection.
Given this I would imagine it’s sensible to attach the mppt here too - leaving the bms to control the battery status.
I presume I can connect the rest of my loads to here too?
I’m a little lost as to why it would be needed to run a charge connect/disconnect directly to the multiplus or the mppt as stated in another example in the manual.
Any help would be much appreciated
BMS
kevgermany avatar image
kevgermany answered ·
If your cable sizes are OK, this will work. Assuming charge parameters correctly set of course.
Best is to bring all the positives to a busbar.
Think about fuses as well. Feed from busbar to fuse box for dc loads keeps things tidy.
