Recently installed RS 450/100 at my home and I straight away noticed a problem where the controller throttles both strings down to under half the rating whilst the controller is in bulk mode. I wondered if there was an issue with cloud shading but this morning has been perfect blue sky and still the RS throttled down the current on both arrays more than an hour before absorption voltage was reached. I also have an mppt 150/85 on the same 48V system both controllers have identical charge settings and are showing as not networked in standalone mode in the Venus GX menu. DVCC is also off. So far the two controllers switch to absorption & float within a few minutes of each other as expected but I am curious as to why the RS is not producing full power when still in bulk mode. It can be clearly seen on the graph below I am getting no error codes from either controller
Any help much appreciated
Scheuten P6-54 210W Tech Sheet.pdf
