The battery configuration in my Navion is different than that of the instructions. My system is setup so that negative terminals are connected together and positive terminals are connected together and what appears to be another shunt as well. I can see the load is coming off one of the negative terminals on the right side of the picture. Under this type of configuration what do I do? Any help would be greatly appreciated. The unit has a generator, shore power connection and solar. In addition, there is a bypass to "jump" the engine if the chassis battery were to die.
