I made the mistake of changing the electrical socket for the temperature sensor that goes on the multiplus.
i made two terminals on the - cable to make it longer as it wasnt long enough to hold inside the green temperature terminal. And a piece of metal got stuck inside the green minus temp terminal.
I cant get it out now. Do you think i can open up the blue cover to get it out. I have tried everything , even shaking it upside down and pushing the orange switch.
