how can I install "make", "git" etc. on VenusOS?
So this command for VenusOS:
apt-get install -y nodejs npm git make g++ gcc
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Venus OS do not use apt but opkg
opkg list |
Display a list of available packages and their descriptions. |
So i did a:
cd /data/conf/signalk/node_modules/signalk-aisstream rm index.js rm package.json
wget https://raw.githubusercontent.com/KEGustafsson/signalk-aisstream/main/index.js wget https://raw.githubusercontent.com/KEGustafsson/signalk-aisstream/main/package.json
thanks, but it is known and unfortunately does not lead to the goal.
When you know VenusOs using opkg and not apt, why asking ?
and in my VenusOs i have make, gcc, npm and nodejs
installed with opkg
but no git, nor necessary since you can easily clone a git repo on another machine and copy it to raspberry pi
I ask because unfortunately I don't have a solution to my problem.
I can install make with opkg install make just fine. But when I want to use it, it says:
"-sh: make: command not found".
The same happens when the compiler is needed. Hence my question about an alternative.
Maybe it's because I have a large image installed
root@raspberrypi2:~# make -v
GNU Make 4.3
Built for arm-ve-linux-gnueabi
Copyright (C) 1988-2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>;
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
root@raspberrypi2:~# gcc --version
gcc (GCC) 9.3.0
Copyright (C) 2019 Free Software Foundation, Inc.
root@raspberrypi2:~# npm -v
6.14.14
root@raspberrypi2:~# node -v
v14.17.4
here is my output:
root@raspberrypi4:~# make -v GNU Make 4.3 Built for arm-ve-linux-gnueabi Copyright (C) 1988-2020 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. root@raspberrypi4:~# gcc --version gcc (GCC) 9.3.0 Copyright (C) 2019 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. root@raspberrypi4:~# npm -v 6.14.11 root@raspberrypi4:~# node -v v12.21.0
when installing for example pybluez via pip I only get errors. Everything red on the console.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
40 People are following this question.
