EasySolar-II-GX-48-3000VA-35-32-MPPT-250-70-GX // 490
All EasySolar-II-GX devices have the latest firmware
I did the programming with VictronConnect, USB MK3.Every change was carried over by the software and the device restarted automatically.The new parameters are then always displayed on VictronConnect.
I did the programming with VE Configure 3,USB MK3. I have the Configuration file changed there, saved and uploaded with Vrm.
Every change was carried over by the software and the device restarted automatically.the new parameters are then always displayed on the VictronConnect.
All possible settings have already been set> Transfer> Checked. Everything OK.
Always the same result: No ECO mode is carried out by the Multiplus.The device does not go into ECO / search mode.
You can also hear that the device ALWAYS remains switched on.You can see on Vrm: No ECO mode. You can measure the current. No ECO mode: Always 13 watts consumption.If I switch off the multilus with Vrm: ZERO consumption.
Usually it is very easy to activate the ECO mode! Where is the mistake.?
