steven-solar avatar image
steven-solar asked
Multi Plus LED Absorption and Float are on. Error?
Hello there.
Multi Plus 48/3000 35-16. SOC 100%.
Bulk LED is off, Absorption and Float are on, Mains on is blinking (that means -as I understand- AC is lead through and no charging is taking place.
This means Error Code 8? But AC Out is available.
Any ideas?
Thanks for helping in advance.
Steven
geomz avatar image geomz commented ·
Is the Inverter On led lit?
steven-solar avatar image steven-solar geomz commented ·
Hello Geomz,
hm, as far as I remember the Inverter-LED was off. I'll observe and report again.
Thanks.
S.
Hi, have you seen our toolkit app? Its available for android and iOS. It can help with these led codes.
If that doesn’t help; I recommend to post a short video here; it will help the people here to recognize the code
steven-solar answered ·
Hi mvader,
no, didn't know about your app yet. I'll try this and mail here the solution.
Thanks.
S.
"Problem" solved: This LED combination means "Feed in with PV Power- Equalisation".
Thanks mvader for the hint with the toolkit.
Wonder why this isn't inside the print documentation which came along with the Multi...
Anyway: Hartstikke bedankt!
Steven
