Good day,
I will install a grid-tied ESS system with a Multiplus-II GX 5kVA device for increased self-consumption, controlled via a ET340 grid meter.
On the grid-side, I would like to use a SMA Tripower 8.0.
In previous installations I used single phase inverters and that works fine, but to have a correct visualisation on the VRM you need to select the right phase in the PV-inverter menu.
Will this choise become unnecessary when using a 3ph inverter or will the L1-L2-L3 choise pop up in the menu?
I want to be sure it is compatible because I checked the manual on this topic but it does not say anything about 3ph inverters.
Thanks for the confirmation.
