wrknowles avatar image
wrknowles asked
BEP TS1 Tank Sender and Cerbo?
I've done my search through the forum posts, and come up with inconclusive results. I'm running a Cerbo with firmware 2.73, and would like to use BEP TS1 ultrasonic sensors. It looks like they should talk with each other running the TS1 as resistive sensors. It also looks like it makes better sense to calibrate the sensors on the Cerbo, rather than using the (rather antique) software for the TS1-PK.
Am I understanding this correctly?
Thanks much,
Walter Knowles
tank monitor
Hi, answered already in part here: https://community.victronenergy.com/questions/89839/gx-tank-140-bep-ts1-ultrasonic-tank-sender.html.. I'll add some more info there.
wrknowles answered ·
Thanks! I'll give it a try. The tanks are fairly large, and I'm guessing that the averaging interval might be able to be set long enough to cover up the fluctuations. I'll keep you posted.
Josep morancho avatar image
Josep morancho answered ·
Hi wrknowles, how was your experience with TS1 and Cerbo GX with your large tank? My water tank is 2 meter tall
