Can you add Amps for the Solar Charge PV section of MQTT?
eg: N/XXXXXX/solarcharger/280/Pv/I
It displays in Victron Connect and VRM but no value is available in MQTT.
Thanks
Mark
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Thanks
Mark
Hi @Mark Maritz,
AFAIK this path has been removed because it can be calculated from Power and Voltage.
It's somewhere in the change logs of Venus OS. So depending on what firmware version you have installed on your GX device you might not get this value anymore.
28 People are following this question.
