atwijukye avatar image
atwijukye asked
Connect easysolar Gx with lynx shun and VE BMS
Dear Team
I am new on this forum and i believe i have made a mistake with my installation. I have a Victron easysolar GX, a lynx shun and a VE can BMS connect to my 25.4 Victron batteries. How do connect the shunt to the BMS and then to the easy solar?Do i connect the RJ45 from the shunt to the BMS and then connect the BMS to the easysolar? i can't find a wiring diagram for this configuration
EasySolar All-in-One
ejrossouw avatar image
ejrossouw answered ·
Just to be sure, you have a Lynx shunt and Lynx smart BMS using VE.Can? If yes, they can be daisy chained with terminators at both ends.
atwijukye answered ·
I don't have a lynx smart bms, I have a ve bus bms with a lynch shunt. My problem is how do I connect the two devices together given that the easysolar has a gx card
Connect the VE.Bus BMS like it is described in the manual.
The Lynx Shunt is VE.Can (250kbit/s) but the EasySolar GX only have a BMS-Can port (500kbit/s).
As far as I know there is a special tool or Firmware with that you can switch the BMS-Can port 250kbit/s. Ask you local Victron distributor about that.
Not sure if we have a victron dealer in uganda. Can I use the BMV shunt instead?
A SmartShunt or BMV could be connected to the EasySolar via VE.direct.
atwijukye avatar image atwijukye Matthias Lange - DE ♦ commented ·
Dear Mathew's, I have a lynx shunt and it does not have a VE direct port. Not sure what I can do but every time I connect it to the easysolar Gx the inverter shuts off. I believe this is because of your previous explanation that the shunt is 250kb/s while the Gs is 500
Fideri avatar image
Fideri answered ·
@atwijukye@mrc.gm
Hello. Did you find a Victron tech in Uganda?
You may contact me directly on info@ntindaview.com
Fideri
