Hi, Victron recommends (https://www.victronenergy.com/live/battery_compatibility:byd_b-box#known_issues) having at least 2 x 2.5KW BYD plus modules, for a 48/3000/35 Multiplus, when in off - grid configuration. I am hoping to use the Multiplus II (35A charge current), with only a 2KW solar PV as the charging current, via a Bluesolar 150/60 MPPT. so the MAX charge current, I estimate will be about 30A, or about 0.6C for a single 2.5KWh BYD module (50Ah), which is what I plan to use...rather than 2 x 2.5KWh modules. Could anyone comment on whether that makes sense? I don't wish to use 2 x 2.5KWh modules, because we overspec'd the Multiplus, for later expansion, at which point there will be 2 x 2.5KWh modules, and 3KW solar.
