Good evening everyone.
Multiplus ii, venus gx, ess with ac pv on the output.
I've noticed on the remote console (local lan), the multiplus avatar shows on/float leds steady as expected. But the inverter led seems to be showing some code - it varies, but 3/8 or 4/10 seem to common.
Is it a code, or just a display artefact? There is no other indication of a problem, and i don't think the real leds are flashing.
Thanks
Russ
