Ok, probably the dumbest question for today but here we go. Can I connect two different voltage batteries to one system for load and charging?
This is what we currently have:
BlueSolar 75/15 with a 200w solar panel connected to a 105amp hour LifePo4 battery (3.2's in 4s config). Couple of other connected systems like a Phoenix inverter and a BMV-712 for monitoring but I suspect they will not impact any crazy plans.
What I want to do is connect a 48amp hour 4s 18650 pack I use to use on this system to give me a bit more storage capacity. So can this be done? Could I just charge the second pack to the lower LifePo4 voltage? Perhaps use a DC-DC Boost/Buck to level out the charge to correct voltages. Is there an intelligent option to charge the second pack when the first is full? Sorry for all the questions, just seems a waste to not use the second pack.
