Hello. I have 2 charge controllers in parallel, one for a lead acid battery, one for lithium ion. While in the Bluetooth network , the lithium ion charger uses the voltage from the lead acid battery sensor. Therefore I suspect it is charging the lithium battery according to this voltage, instead of the lithium battery voltage. Does anyone know if this is just a display issue, or is it a component design oversight?
