Hi, in my RV I plan to connect my air conditioner to the AC2 output of my Multiplus because I never want to run the air conditioner with the inverter. But the Multiplus will pass through my 30A service on AC2. My air conditioner circuit is a 20A circuit (12 gauge wire). Is there a way to limit the current on the AC2 output? Is there a fuse that can be changed or a programmable setting?
I'm trying to avoid having to install a sub panel for this one circuit.
