Whilst on the boat I would like to use a DMC to regularly switch Multi on and off, but when away from the boat be able to switch the Multo on and off via the VRM Remote Console.
To disconnect the DMC when leaving the boat, can I insert a switch in to one of the wires in the RJ45 cable, if so which wire?
