i just set up my home automation system to calculate the next Day PV-Yield, very nice and it works very well:
With this as base i am now able to set the MinimumSocLimit (in ESS, without Battery Life), manually at the moment.
I use MQTT to connect all the stuff to my Home Automation.
Is ist possible to set the MinimumSocLimit via MQTT ?
I already see the xls-File with Modbus-TCP - D-Bus register settings an it is writable ... (with Modbus-TCP)..
But i had no success with MQTT:
Thank you for the help !
regards Yves.
