Installed an Easysolar, and in the midst of setting it up for the lithium batteries, which have a charge voltage of 14.4V and a nominal charged/rested voltage of 13.3V. The Easysolar has a Multiplus and a MPPT inside.
From what I have gleened from here, the manuals and elsewhere on the net, the Multiplus voltages should be matched to the battery - absorption 14.4 and the float 13.3, rebulk -0.2, fixed absorption, absorption time 2hrs, no tail and no equalisation. 'Lithium batteries' mode enabled.
What should the bulk-finished percentage be on the Multiplus (default 85%)? Should this be adjusted? I thought with lithium, it's a bulk charge almost to the last.
What should the MPPT voltages and settings be set at? The same? Or slightly higher - I read that is needed to raise the bulk-finished on the Multiplus?
My brain is about to fry, and I don't want to ruin my batteries due to my lack of knowledge on the subject. Any advise is greatly received.
Thanks, Brad
